ALTUI : New Features Suggestions
Ok, thanks and I know an alternative… but how can Datamine (and datamine2) do it? out of the appstore?
Another alternative is to put the following file on Vera’s /www/
<!DOCTYPE html>
<html>
  <head>
    <!-- HTML meta refresh URL redirection -->
    <meta http-equiv="refresh" content="0; url=/port_3480/data_request?id=lr_ALTUI_Handler&command=home#">
  </head>
</html>
then the url:
http://VeraIP/altui.html
will start AltUI.
[quote=“akbooer, post:322, topic:188330”]Another alternative is to put the following file on Vera’s /www/
<!DOCTYPE html>
<html>
  <head>
  </head>
</html>
then the url:
will start AltUI.[/quote]
Ok, that is a good alternative as well. How would I place that on the “www”?
I just ran this code in Lua Test:
local f = io.open ("/www/altui",'w')
local x = [[
<!DOCTYPE html>
<html>
  <head>
  </head>
</html>
f:write(x)
f:close()
[code]
local f = io.open (“/www/altui”,‘w’)
local x = [[
]] f:write(x) f:close() [/code][/quote]
that works but I am not sure the parameters will transit to the redirected page so you have to accept to give up on the url options features.
Uhm… what about my question in relation to the oit of the box functioning of datamine? Why does it work there and why is it not easy to make such a link?
Hi Sender,
As shown by amg0 and akbooer (and datamine) it can be done but is not recommended. So you can do it on your own system with the instructions above, but do not expect it will become part of standard ALTUI functionality.
Cheers Rene
Can I please suggest:
  1. you are looking at the Scenes page
  2. you select a room to view the scenes that are part of that room
  3. you select Scenes +Create button.
  4. You have now entered the scenes create page
Change code so that the room defaults to the room you have selected not “No room”
[quote=“a-lurker, post:328, topic:188330”]Can I please suggest:
Change code so that the room defaults to the room you have selected not “No room”[/quote]
ok, next release
I really like the new timeline! It would be even better if it had an indication of the state not just the change. Maybe a color visual reference, like green for untripped and red for tripped. Or at least a 1 or 0 to indicate new state.
Thanks!!
Hi–
I really like altui but have a couple of suggestions:
  1. The various network charts are very good but could you provide a legend of the various colors?
  2. Getting the error “Unknown control type:js_button” on the cvarious camera and no image. Can you give me a hint on how to fix it?
  3. Can you put a scroll bar on the devices page. I can’t see (or get to) all of the rooms without changing the window size
Z
[quote=“Zoro, post:331, topic:188330”]Hi–
Z[/quote]
1: is kind of hard, will look into it, it is a color per device type but there could be many different types.
2: need more details like the device name, device type , device JSON file to dig more
3: ALTUI avoid scroll bars as it must work on mobile device too. you can uncheck the option “Buttons are fixed on the page” so that they scroll along with the page
Would be nice to have <</Home/[b]Panels/b/current page rather than <</Home/current page to give one click access to use custom pages
I’m starting to use custom pages quite a lot because it allows mixing of commonly used commands from a mixture of scenes/devices
thank you
[quote=“NikV, post:333, topic:188330”]Would be nice to have <</Home/[b]Panels/b/current page rather than <</Home/current page to give one click access to use custom pages
thank you[/quote]
ok, beta version in master branch of GitHub - amg0/ALTUI: Enhancement Interface for VERA home automation system
Whats the easiest way to update to the beta version ?
[quote=“NikV, post:335, topic:188330”]Thanks
Whats the easiest way to update to the beta version ?[/quote]
You go to the URL , find the button download zip , then open the zip and extract the files. Upload the files using ui7 apps menu, develop apps then the file upload feature.
right thats what i did and got version 1982 but I dont see any change to the line with <</Home/currentpage - see attachment
thanks
edit: this is running under openLuup if that matters
Ah Ive just compared it with vs 1981 running on the vera and I can see it adds the name of the custom page you are viewing :slight_smile:
What I originally meant was to have a link like Home so you could jump straight to Use custom pages where ever you were (like you can jump to home from where ever you are) rather than clicking panels > use custom pages sorry communication issue, alternatively have the panels button to go straight to using custom pages and out the edit custion pages on misc or more
or possibly be able to customise where the home button takes you to?
thanks
[quote=“NikV, post:338, topic:188330”]Ah Ive just compared it with vs 1981 running on the vera and I can see it adds the name of the custom page you are viewing :slight_smile:
thanks[/quote]
humm that changes quite a bit the internal logic, but have you tried direct ALTUI open links like
http://your_ip/port_3480/data_request?id=lr_ALTUI_Handler&command=home&home=pageUsePages
http://your_ip/port_3480/data_request?id=lr_ALTUI_Handler&command=home&home=pageUsePages&nPage=0
http://your_ip/port_3480/data_request?id=lr_ALTUI_Handler&command=home&home=pageUsePages&nPage=0&layout=lean
yes - trouble is I usally have altui open all the time on a tab so was trying to find a quick way to go straight to custom pages from where ever I am in altui - I use the examples you gave on tablets so the kids can go to their relavant page
