During the last few weeks Alexa can’t control my VeraPlus devices, in some cases I get acknowledgment from Alexa but nothing happens, in other cases I get error.
When looking at the devices via the Alexa app, all of them are unrecognized or some other error, however I am always able to turn lights on , but never off.
I am experiencing the same. Using Alexa to control my Vera Edge more or less stopped two weeks ago. Once in a while it does work but mostly non functional atm.
I’ve had a stable system for a few years. Occasionally, an Alexa voice command would time out, but it worked pretty well.
Recently (last few weeks), scenes that Alexa should control don’t work at all (“ is not responding”).
If on the other hand I ask Alexa to “turn on the lights”, that will work, but it is followed by the following message: “Sorry, the device that is connected to is not responding. Please check its network connection and power supply”). My hub works fine, and I can control the scenes perfectly well by other means (eg my phone / computer).
The problem appears to be a little transitory - that is it has come and gone a little.
We kindly invite our customers having issues with the Alexa integration to disable and re-enable the corresponding skill (for Vera or Ezlo). The Alexa integration had some issues in the past few days but this should fix it. However, if the persists, please let us know at support@ezlo.com so we can troubleshoot directly. We are sorry for the inconvenience.
Thanks a lot!
