I then used the Vera mobile app connected to the Atom and I can see this new Test switch. Cannot actually make it turn ON however. But its there, its also visible in the new web GUI, same in there I cannot turn on the Test switch either.
Back to the Ezlo Plus it looks like the plugin is installed as its files are there:
Looking in this log file ha-extensions_manager.log in this folder /tmp/log/firmware after trying to create the virtual device I am seeing this:
2021-04-27 19:30:03.778688 INFO : Running plugin script: HUB:test_plugin/scripts/generate_devices
2021-04-27 19:30:03.779268 WARN : Plugin test_plugin is not registered
Just rebooted the Ezlo Plus hub and now I see this in the same log file, so it looks like the plugin is starting OK.
2021-04-27 19:33:17.626022 INFO : Plugin started: test_plugin-1.0.719
2021-04-27 19:33:17.639362 INFO : init: GatewayPlugin: the gateway (test_plugin) got registered for the plugin (test_plugin-1.0.719)
2021-04-27 19:33:17.650416 INFO : Plugin: request to start the plugin (test_plugin-1.0.719, HUB:test_plugin/scripts/startup)
I then used the Online API Tool again and attempted to create a new device.
And this time its bloody working !
I saw this in the log file
2021-04-27 19:36:48.948960 INFO : Running plugin script: HUB:test_plugin/scripts/generate_devices
And a new virtual device has been created on the Ezlo Plus.
Wish I rebooted it earlier it would of save me a lot of hassle and time !
I can see this new device in UI1, its called it TestSwitch_2 for some reason. The one created earlier on the Atom is named “TestSwitch”.
I can turn this one on and off OK also, so all good.
Does anyone have a link to a list of devices, i.e. “device_type” that we can create?
I am thinking about using this to trigger a scene based on my home mode by setting sensors in the mode configuration. I’m thinking about using a door/window virtual sensor for this.
I’ve just exposed an existing virtual switch device I previously added to my Ezlo Plus hub, by using the home.getvera.com Web portal page for “Manage Alexa Ezlo”.
And Alexa just announced it had found a new device called “TestSwitch” and I can also see and control this virtual device switch in the Alexa app.
At the moment seems that Alexa and Voi is not working as expected for many. Opened a jira support and seems that they know this issue;
About GarageDoor, is this a relay switch? I did a test using also “scope” from reactor and seems that it does nothing, at least I can’t use it in the same scene where I have a relay switch from Switchboard Plugin and I can’t control a phisical realy.
Still problem with Alexa, to recognize new virtual devices on EzloPlus.
At the moment I have one on testing, Alexa can’t change virtual dimmer from any level to 0.
When I put it to 100%, takes many seconds. The test is done using virtual dimmer on Vera and in the same time on EzloPlus.
In MSR it never takes 100%, only 99%.
Still understanding how to use garagedoor, seems it never goes ON. is there an example?
Thanks in advance
Hi, virtual devices are creating with test_plugin (method 1 with ssh) and then with apiTools.
From ManageAlexa, under the list ezlo hub, they are not in the list to be selected and also scenes don’t appear.
In EzloAlexaManage appear some of them, but not all the devices.
Then on Alexa app on android they result not available, in red circles, so can’t control them
I’ve just created a new Dimmer virtual switch on my Ezlo Plus hub and it has NOT appeared in the “Manage Alexa Ezlo” web portal setup page. So I cannot expose it to the Alexa app.
I also checked in the other portal page “Manage Alexa” which should be for Vera firmware hubs and the new dimmer virtual device is not listed in there either.
These voice assistant web portal setup pages have been broken for years and it seems they are getting worse and worse as now I cannot even load the “Manage Google Home” page at all and that is the one I mainly need to use for my production Vera Plus hub and my Google Home setup.
