Aeotec Multisensor 6 (AEZW100A) - anyone used it?
Update on experiences, research from many forums, and many direct conversations with Aeotec on this Sensor.
Short Version:
Recommended Buy: NO
  • I cannot recommend this sensor unless you are ready and able to run a USB power cable to the location.
General Issues:
Documentation that is include with the sensor, and the ones downloadable are VERY incorrect and incomplete. They have VERY wrong values for the Parameter settings and you’d not be able to figure it out on your own. And the way the docs explain how things work is also VERY wrong. I explain (the short version) below how it really works.
Problems and Product Shortcomings when on Battery power:
  1. Motion is the only sensor that reports quickly / instantly
  2. All non-motion sensors report only when the unit is Awake. The shorted time you can set Wake Interval to is 240 (seconds). I have done this and killed 4 batteries… batteries only last 2 weeks, per set of 2, when using 240 seconds. They recommend leaving the default Wake to 3600 (12minutes)
  3. UV sensor does not seem to report, ever, no matter what
My last communication with Aeotec was that he’d let me know if he hears back from Engineering to see if they can ‘fix’ this in firmware and allow the non-motion sensors to report based on a Parameter setting even when on Battery.
Unless you are OK with Temperature, Humidity, and LUX reporting only every 12 minutes (and not having UV at all)… which makes the values useless for most automation tasks, then this sensor is mainly just an expensive motion sensor and I recommend buying the Monoprice motion sensor as they are less than half the cost.
[quote=“Aaron, post:1, topic:187238”]Looks like this thing does all sorts of stuff… http://aeotec.com/z-wave-sensor
Anyone tried one, or know if Vera UI5 will actually support all the functions properly?[/quote]
Well since it hasn’t been released yet (end of this month for pre orders) I would think your not gonna find much info on it.
Very Bottom of Page:
Where to buy MultiSensor 6.
Where to buy.
MultiSensor 6 is available for pre-order at the following online retailers:
United States:
The Smartest House (pre-order)
HA World b[/b]
Netherlands: ROBBshop b[/b]
What a strange company, the announce all kinds of things, like smart film, and never deliver or deliver years down the road. i wouldn’t hold my breath
Are you saying that make a great VERA partner?
The device I posted is actually for purchable. People on smarthings site have them
Amazon indicates "This item will be released on June 6, 2015. "
I was looking at HomControls. You are correct. I missed the fine print… “Accepting Pre-Orders Only. Expected to ship in late May.”
http://www.homecontrols.com/aeon-labs-aeotec-z-wave-multi-sensor-6?sc=23&category=78157
Will it work with Vera3? It claims it needs a Hub that supports the Gen5 (Zwave 500 chip) to get access to all features.
“You need a Z-Wave gateway which operates with the 500 series chip products to take full advantage of the device. Please consult the manufacturer of your Z-Wave hub to make sure it supports all MultiSensor 6 features”
http://thesmartesthouse.com/collections/vibration-sensors/products/aeotec-by-aeon-labs-z-wave-5-in-1-multisensor
Zwave+ is only supported by VeraEdge … no reason now to buy a new VeraLite type controller
[quote=“pascalw, post:8, topic:187238”]Will it work with Vera3? It claims it needs a Hub that supports the Gen5 (Zwave 500 chip) to get access to all features.
http://thesmartesthouse.com/collections/vibration-sensors/products/aeotec-by-aeon-labs-z-wave-5-in-1-multisensor[/quote]
Usually they are backwards compatible to a certain extent. Since you are asking about a device that is not even out yet. None of us even know if it will work with vera when it’s released. Recent z-wave plus or gen 5 devices have been having problems and vera has had to release fixes to make them work properly. So you safe bet is to let it get released and have people try it out. At this point no one knows how it works with anything since it doesn’t exist in the wild yet.
I received my new MultiSensor 6 today, but it installaed as a GenericIO device. To get it working, I did the following with my VeraLite running UI5 Ver-1.5.672.
Under the Advanced Tab, change the following:
device_type:
DELETE: urn:schemas-micasaverde-com:device:GenericIO:1
ADD: urn:schemas-micasaverde-com:device:MotionSensor:1
device_file:
DELETE: D_GenericIO1.xml
ADD: D_MotionSensor1.xml
Hope that helps,
Tom
[quote=“ZW-Tom”][quote=“Aaron, post:1, topic:187238”]Looks like this thing does all sorts of stuff… http://aeotec.com/z-wave-sensor
device_type:
device_file:
Hope that helps,
Tom[/quote]
What functions show?
Sent from my HTC6525LVW using Tapatalk
[quote=“Aaron, post:12, topic:187238”][quote=“ZW-Tom”][quote=“Aaron, post:1, topic:187238”]Looks like this thing does all sorts of stuff… http://aeotec.com/z-wave-sensor
device_type:
device_file:
Hope that helps,
Tom[/quote]
Sent from my HTC6525LVW using Tapatalk[/quote]
Functions include Temperature, Humidity, Light, Motion and one called Sensor. The one called Sensor does not display any level. Not sure if it is vibration or UV.
I also installed it on my VeraEdge and it did the same thing, installed as GenericIO device.
Tom
Hey Tom, that worked for me following your instructions. Still trying to figure out how to get the UV sensor working, I am thinking the device file is the wrong type but not sure if there is a UV device file.
[quote=“ZW-Tom, post:11, topic:187238”][quote=“Aaron, post:1, topic:187238”]Looks like this thing does all sorts of stuff… http://aeotec.com/z-wave-sensor
device_type:
device_file:
Hope that helps,
Tom[/quote]
who did you order from? everything now says pre-order until july 5th
The device file is UVSensor1.xml, but it is not supported by Vera.
Tom
[quote=“mvader, post:15, topic:187238”][quote=“ZW-Tom, post:11, topic:187238”][quote=“Aaron, post:1, topic:187238”]Looks like this thing does all sorts of stuff… http://aeotec.com/z-wave-sensor
device_type:
device_file:
Hope that helps,
Tom[/quote]
who did you order from? everything now says pre-order until july 5th[/quote]
I pre-ordered from thesmartesthouse.com but I see they are now sold out until July 5th.
Tom
If Vera decides to support this MultiSensor (Or any new device for that matter), does UI5 get the upgrade or will only newer versions of UI7 be supported?
Haven’t been around long enough to know if UI updates include zwave updates or if its a separate thing.
[quote=“aurora912, post:18, topic:187238”]If Vera decides to support this MultiSensor (Or any new device for that matter), does UI5 get the upgrade or will only newer versions of UI7 be supported?
Haven’t been around long enough to know if UI updates include zwave updates or if its a separate thing.[/quote]
pretty sure they are supporting UI5 anymore… they like to support UI7… the most recent, most buggy (by a mile), worst version.
[quote=“Aaron, post:19, topic:187238”][quote=“aurora912, post:18, topic:187238”]If Vera decides to support this MultiSensor (Or any new device for that matter), does UI5 get the upgrade or will only newer versions of UI7 be supported?
pretty sure they are supporting UI5 anymore… they like to support UI7… the most recent, most buggy (by a mile), worst version.[/quote]
Yup, definitely sure it’ll be UI7 and higher only. UI5’s days are numbered. Ultimately we’ll have to decide on upgrading firmware or controller. Not looking forward to that day.
