Here is my case
I have 2 floors house
My vera is in teh GF close to my door lock
My very left room z-wave devices in the FF are not responding
unless i get my vera closer
so i decided to add vera lite to that room and some other rooms up especially for sensors
How do you suggest to do so in Z-wave
like to use the vera lite as a REPEATER
You can not use a vera as a repeater but have that Vera control those z-wave devices and incorporate that Vera into the other vera. Do a search for bridging veras, there are a few posts explaining how to do it.
I know those ways, they relay on LAN Network
I want to bridge my veras via z-wave
like from add device and add vera
i want more information on that
I dont wanna loose all my network
Vera doesnāt work that way, but many native Z-Wave modules do. Can you not simply fill in the Z-wave network with a couple of modules (not battery powered) to increase the density of the mesh in a few strategic locations?
Another idea is to upgrade the antenna on your Vera, there are a number of posts on this forum about that and the results reported have been pretty good.
I recall many have spoken of distant nodes becoming responsive again.
So at $15-20 to do it (assuming you want to, due to warrant concerns) it would be much cheaper that buying two.
My option will be use 2 verasā¦(like recommended by micasaverde)
1st I will go add to a vera all devices of floor 2ā¦
2nd I will go add all devices of floor 1 to another veraā¦
3rd I will choose the vera1 like masterā¦and add another vera (the first one) using UPNPā¦
I read I will can creates scenes in vera1 using devices of vera2ā¦itās for me will be good.
My doubt is when I need add another device to floor2 (slave vera) it will appears on vera master automatically ???
Do you have all four veraās included into each other both ways? The slowness could be the fact that all four are updating when changes are happening and you are taking a small performance hit.
My guess is that would work fine / you get the same functionality (but including/excluding needs to be done on the primary). Donāt know how node configuration and route optimization (āthe nightly healā) is handled in that case.
Havenāt seen many reports on folks doing this, and havenāt tried myself. The preferred way is presumably bridging, so you get to manage everything (or most of it) on one Vera.
After testing the network
All veras are working from the same master vera
(i did an add using upnp)
the problem is that it is SLOW!you know i am facing some delays
and I only added veras one way (all to one vera)
Today one of my devices (in vera #74) is not working from the master vera but another device from the same vera (vera #74) is working
and both are working fine from thier original vera #74
Lesson learnt:
All cameras should be added to the Master vera. Otherwise you wonāt be able to see them from SQ Remote
