hello folks !
please check if some that motors can put in this system
the system:
http://www.remotecontrolcurtain.com/product3.html
the motors:
http://store.homeseer.com/store/Shade-Blind-Control-C192.aspx
thanks !
hello folks !
the system:
the motors:
thanks !
Did you not see my answer here:
http://forum.micasaverde.com/index.php/topic,11125.msg80676.html#msg80676
The motors you have linked have their own internal radio controller and will not work with the Zwave controllers you posted a link to. For those controllers you need either an AC standard 4-wire motor or a DC standard 2-wire motor. Rollertrol offers standard motors I believe.
OK shady !! thanks !!!
Shady and anothers …hello !
my supplier is saying this about him motor:
[i]System III has an option of Wall Control with a 5-pin port for “dry contact” to relays of automation systems. See attached for the specifications.
It looks like this should work if it connects to your zwave control:
http://store.homeseer.com/store/Smarthome-2450-IO-Linc-INSTEON-Low-Voltage-Contact-Closure-Interface-P1240C178.aspx
Please consult with the installer as I am not familiar with these systems.
Electric Remote Controlled Roller Shade System III
— see: http://picasaweb.google.com/RemoteControlCurtain/RollerShadeIII?authkey=Gv1sRgCIi84sD6gJ-ZiQE#[/i]
I ask: have some device like that insteon what I can add to vera3 network ???
thanks one more time !
Chances are that you can find a way to trigger the dry contact, like you said with either a Zwave to dry contact module (Fortezz MIMO or Insteon or other device). You might ask how many wires are used for their dry contact ( is it just up/down/common or up/down/stop/common) so you know how many contacts you need available on the Insteon or Zwave device.
I can help you. You can contact me online or you can find me at www.tubularmotor.us Ask for Ovi 1-216-255 7212 or at tubularm@yahoo.com
http://www.tubularmotor.us/timers.html
http://www.tubularmotor.us/sensors.html
http://www.tubularmotor.us/other.html
http://www.tubularmotor.us/receivers.html
