So I finally got my ZRF113 relays, and am psyching myself up for wiring them up and jumping off that cliff. Given the number of posts (and I realized it may be that all I am hearing are the squeaky wheels in search of grease) from folks having their Vera setups start having Brownian behavior (lights going on middle of the night for no reason, frequent Vera self-reboots, etc), I am thinking hard about achieving only the function we really care about–being able to remotely close the garage doors. We don’t care about opening them remotely.
I could try to do this a bazillion ways where I have some sort of sensor that Vera can check against for door status, and only briefly close the ZRF113 and toggle the door state when Vera thinks it’s open. But none of the Zwave sensors reliably do this. I’ve considered RFID, pseudo-devices, and can see where they all can fail, especially if Vera starts rebooting randomly.
Our doors are Liftmasters. There’s a solenoid that pops a rod into the door track when the door is completely closed, and this has an external knob on it so the blocking rod can be pulled back to allow the door to be released and opened in an emergency.
Here’s what I’m thinking, and I know it’s pretty low-tech: place a limit switch in series with the load contacts of the ZRF113, having that switch go “open” any time the solenoid goes into its locked position. If the door is already closed, actuating the ZRF113 does nothing, since the limit switch will have broken the circuit. If the door is in any position but closed, actuating the ZRF113 will close it.
Thoughts? The travel on this “knob” on the solenoid is well over an inch, so I should have a pretty easy time afixing a magnet to it and mounting a magnetic contact switch nearby, or even using a mechanical limit switch. This keeps all of my bits clear of the door track. If the bits fail, say the magnet falls off, I’m planning on setting this up so the switch is normally open and only gets closed when the solenoid rod is retracted, so the failure mode will be to do nothing.
I’m probably being too paranoid, but would really hate to come back from a long weekend away and find that my home automation bits chose to open the garage doors and leave them that way.
–Richard
PS: In conjunction with the above, I’ll be putting a WiFi PTZ in the garage facing the doors, so we can visually verify status and absence of neighbor children (well, except a couple) before we initiate closure.
