You linked the same product twice and I’m not sure if that was a accidental double paste or you meant to link to the other required product. I believe the link you have is the second part to a three way switch. This is the product I use to control a fan with vera:
I think I saw another GE fan switch on Amazon as well.
I also used a seperate dimmer light switch. I had to create a 12/4 to get this wired correctly.
The fan switch has been working well for us since October 2014.
Courtney
