Since the latest firmware release (my hub is running 2.0.48.2397.3), it seems I get regular, repeated restarts of the zwave extension. This triggers a scene to run, turning lights in my living room on on unwanted times of day.
I thought this was due to the FGD-212 support included in the firmware, but it might be unrelated to that.
This is what I get in the ha-extensions_manager.log:
2023-12-22 11:02:53.424311 INFO : Running plugin script: HUB:foscam/scripts/handlers/foscam_events_handler
2023-12-22 11:06:09.651812 INFO : Addon stopped: zwave-1.0.2397.3
2023-12-22 11:06:16.442614 INFO : Addon started: zwave-1.0.2397.3
2023-12-22 11:06:16.442825 INFO : Plugin restarted: zwave-1.0.981
2023-12-22 11:06:16.465354 INFO : init: GatewayPlugin: the gateway (zwave) got registered for the plugin (zwave-1.0.981)
2023-12-22 11:06:16.481052 INFO : Plugin: request to initialize migration(zwave-1.0.981, HUB:zwave/scripts/migration/initialize_migration)
2023-12-22 11:06:16.520583 INFO : Plugin: request to migrate device(zwave-1.0.981, HUB:zwave/scripts/migration/migrate_device)
2023-12-22 11:06:16.535099 INFO : Plugin: request to finalize migration(zwave-1.0.981, HUB:zwave/scripts/migration/finalize_migration)
2023-12-22 11:06:16.558351 INFO : Plugin: request to start the plugin (zwave-1.0.981, HUB:zwave/scripts/startup)
At the same time, this is logged in ha-zwaved.log:
ha-zwaved.log:2023-12-22 11:06:09 ERROR : Terminate instance...
ha-zwaved.log:2023-12-22 11:06:09 INFO : Logs folder was changed: /var/log/firmware
ha-zwaved.log:2023-12-22 11:06:09 INFO : addon.zwave: at-release/2397.2-3-g884510ea5eff55d2bc95912d [2023-11-27T22:03:00+0000]
ha-zwaved.log:2023-12-22 11:06:09 INFO : addon.zwave: Spread: connected to "4803" with private group "#addon.zwav#localhost"
ha-zwaved.log:2023-12-22 11:06:12.578288 INFO : zwaveModuleResetPinAssert: Assert reset on zwave chip
ha-zwaved.log:2023-12-22 11:06:12.579282 INFO : zwaveModuleResetPinRelease: Deassert reset on zwave chip
ha-zwaved.log:2023-12-22 11:06:13.080665 INFO : Zwave reset is completed
ha-zwaved.log:2023-12-22 11:06:13.125706 INFO : ZWave stack initialized successfully
ha-zwaved.log:2023-12-22 11:06:15.835271 INFO : Home ID: 0xE40D8454 Node ID: 1
ha-zwaved.log:2023-12-22 11:06:16.440269 INFO : znetInitFinish
ha-zwaved.log:2023-12-22 11:06:16.440652 INFO : activateMode Monitoring
ha-zwaved.log:2023-12-22 11:06:16.440796 INFO : znet_smart_start_listen_mode_enable
ha-zwaved.log:2023-12-22 11:06:16.440988 INFO : setUp: Zwave addon setup done !
ha-zwaved.log:2023-12-22 11:06:16.441027 INFO : activateMode Time synchronization
ha-zwaved.log:2023-12-22 11:06:16.441190 INFO : znet_smart_start_listen_mode_disable
ha-zwaved.log:2023-12-22 11:06:16.442257 INFO : activateMode Monitoring
ha-zwaved.log:2023-12-22 11:06:16.442575 INFO : znet_smart_start_listen_mode_enable
Not much else happing in the logs at that specific time, so not sure where to move from here.
This happens once per hour:
ha-watcher.log:2023-12-22 06:05:47.975427 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 06:05:48.768705 INFO : Z-Wave Service Restarted
ha-watcher.log:2023-12-22 07:05:52.215878 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 07:05:52.571624 INFO : Z-Wave Service Restarted
ha-watcher.log:2023-12-22 08:05:56.507681 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 08:05:56.842761 INFO : Z-Wave Service Restarted
ha-watcher.log:2023-12-22 09:06:00.778188 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 09:06:01.112585 INFO : Z-Wave Service Restarted
ha-watcher.log:2023-12-22 10:06:05.006261 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 10:06:05.343447 INFO : Z-Wave Service Restarted
ha-watcher.log:2023-12-22 11:06:09.566038 INFO : Z-Wave Service Restarting...
ha-watcher.log:2023-12-22 11:06:09.898669 INFO : Z-Wave Service Restarted```
Hopefully this can be fixed, or at least running of scenes can be suppressed during this event.
