Am I alone in being frustrated with the cost of Zwave devices in Australia, particularly when it comes to switching loads above 650watts?
I’ve spent a small fortune on Aeon and Fibaro devices and got most of the house covered but I’ve still got a way to go. Fibaro seem to be the only option for higher load devices with their 1.5kw and 3kw switches, has anyone found any other reasonably priced options?
I don’t really understand why the manufacturers aren’t building devices that support larger loads at a reasonable price.
I’ve got so frustrated with it I’ve decided to build my own controller for the bathroom.
It supports eight switches with up 40 amp loads (which is overkill I suspect but I thought it best to err on the right side!) and also includes a four normally closed security sensors inputs (for the door, motion and windows), a couple of temperature sensors, humidity and lightlevel. With this I can control my Tastic (Fan, two heat lamps and light), vanity light, heater, the powerpoint that the hairdryer and straightening wand use (which my better half regularly leaves on) and a little audio amp with bluetooth, radio and auxiliary input. I’m currently working on adding an IR blaster to it to control the little audio amp and any other IR devices. So far it has cost me less than $300 which is a lot less than it would have cost me to switch the eight loads, let alone monitor temperature, humidity and light. It isn’t a zWave device, my current version has a hard wired ethernet connection but I’ve started work on a WIFI version. I’m new to Vera coding and having been 20 years since I cut code, I’m pretty rusty but I’ve managed to put together device files to make it all usable in Vera.
Has anyone else gone down this path?
