ZWave bridging: possible to use Vera1 in a Vera3 setup?
Is it possible to use an old Vera1 to bridge the ZWave network that’s set up on a Vera 3?
What should I do to see if it’s working?
Please do a search. There are many threads based on bridging vera units.
Have a look here:
http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines
and
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Pro&page=multiple_units
To make things easier, make sure that Vera 1 is on UI4.
  • Garrett
I have had no success tying to bridge UI4 with UI5, it will import but but ends up configuring lights with no on off switch some sensors import correctly, others not, forget about the thermostat, even using two units with the latest software has quirks though it’s very cool when it works
Hi Garett,
I did, and did not find what I needed. I followed the instructions and I have a device in my list that represents the other Vera.
Thanks prgrover, although I had hoped for something like “It Just Works ™ after inclusion”. Alas…
Best regards,
Mark
