ZRF113 or ZRW113 for Gas Fireplace
Anyone using the ZRF113 or ZRW113 for a gas fireplace with low voltage contact switch? I was actually thinking about initially just installing the ZRF113 under the fireplace where all the rest of the electrical is as I can easily get power there. I was also thinking about wiring the load in line with the current low voltage switch giving me a breaker of sorts on the fireplace so that when we will not be home for extended periods of time I can shut off the access to the fireplace switch for the ZWave system. Thoughts or experience?
Did you get this working? I have a standard decora wall switch with low voltage wires hooked up. I want to replace it with a z wave switch.
