I bought the new Zooz 700 Series Titan Water Actuator to use with my Vera Plus (and possibly my Ezlo Secure). The water valve controller paired fine with Vera, but it showed up as a light bulb with on/off control. The device also displayed a battery indicator that read 0% (It’s a powered device with there’s no battery connected).
In case anyone else is searching how to correct these problems, here’s what Zooz customer support says to do:
If you would like the Titan actuator to display as an open/close valve, please follow these steps:
In the Vera online (browser) interface, select the sensor, then click on Advanced.
Go to the Params tab and make the following changes:
device_file: D_WaterValve1.xml
device_json: D_WaterValve1.json
Save changes and go back to your device list to see if the device now displays correctly.
AND to have the valve properly show Open/Close:
It sounds like you may need to change one of the settings to get the status synced:
- Open your Vera online interface (the browser dashboard, not the app)
- Click on the Zooz Valve Actuator ZAC36
- Go to Device Options
- Click on Add configuration settings
- Put in the following:
- Variable = 17
Data Size = 1 byte dec
Desired Value = 0 -
- Click on Save Changes
The battery setting can be ignored as it relates to the back-up battery unit that’s an optional accessory and currently not available for the Titan actuator.
When I reached out to Vera/Ezlo support, I was advised that the Zooz ZAC36 is not supported and may not work as desired. However, it has been working fine since making the changes listed above.
