I installed an EVL-4 and got the zones configured. I can see the armed / disarmed status for each sensor in my vera device control panel but I can’t see when doors or windows are tripped, aka when someone opens a door, vera doesn’t detect anything, no red bars over the top.
Quick question - when you arm your alarm panel (via keypad, key fob etc), do the sensor devices set up in Vera change their status to armed - and then unarmed once the alarm is disarmed?
[quote=“jarrodirwin, post:4, topic:199567”][quote=“KennyCoolHeat, post:2, topic:199567”]Looks like I got it fixed, needed to add the port number on the IP setup
Quick question - when you arm your alarm panel (via keypad, key fob etc), do the sensor devices set up in Vera change their status to armed - and then unarmed once the alarm is disarmed?[/quote]
No they do not. The Armed /disarmed you see is for Vera modes and not for your alarm system. You should only see the status change on the device itself.
