I have a Vera Edge controller with the latest Sonos app version installed.
I have three Sonos ZPs: two PLAY:1’s and one PLAY:5.
All three devices work just fine but one of the two PLAY:1’s shows a generic Sonos icon not the PLAY:1 icon. I have gone into Advanced > Variables and changed the value of SonosModel from 0 to 6 which is the value that the PLAY:1 with the icon reports. After setting this, the icon changes to the correct icon for a PLAY:1 however after a minute or so, it reverts back to the default icon.
Is there any way I can make the correct icon for it as a PLAY:1 stick?
i also have the same issue, 5 zones, 3 play 1’s and a play Bar all except the newest Play 1 have the correct icons. the newest was purchased in November.
wondering if this is because of changes to new hardware.
OK i believe i am right, if i look at the properties of my Sonos’s which have the correct logo when clicking on properties in windows explorer on my pc i see in the Model Number S1, however on the newest Play 1 this shows as S12 indicating its a second revision of the Play 1
the I_Sonos1.xml file contains the following entry
elseif (values.modelNumber == “S1”) then
model = 6
i just added a new section beneath this that says
elseif (values.modelNumber == “S12”) then
model = 6
presumably that will be the same for the new Sonos 5 and 3 which by the rationale of the S1 would be called S32 and S52 but i dont have the devices so cannot check, but for those who do can you check so we can get the sonos plugin actually updated with these new versions.
[quote=“fuzzysb, post:4, topic:195012”]ok i have fixed this for my play 1
model = 6
model = 6
presumably that will be the same for the new Sonos 5 and 3 which by the rationale of the S1 would be called S32 and S52 but i dont have the devices so cannot check, but for those who do can you check so we can get the sonos plugin actually updated with these new versions.[/quote]
Have just checked Windows Explorer the same as you and correct, one of my PLAY:1 devices reads S1 and the other reads S12, nice find. Are there device configuration files for the PLAY:Connect as I’m thinking about buying one of these and would like to work properly too.
