Had high hopes this very inexpensive 720P outdoor camera with nightvision/IR-cut could be manually setup with Vera as a generic IP camera, but it does not appear to be possible. I just confirmed with their tech support that no provision for obtaining a still jpeg image via a URL exists. Really a shame as the image quality and construction of this camera is excellent, especially for under $100.
Before I bought this camera I had found on the forum that another user had success adding a Zmodo IP cam, but an older model. The folks at ispyconnect also list many Zmodo camera models with support for jpeg capture, so it sure seemed reasonable that this new model would be no different.
If Vera could support capture from a H.264 stream or support the ONVIF standard this Zmodo model would be a great choice. As it is now, I will need to return it.
yep, had the same problem. it’s surprising that they decided to give up on JPEG support in newer models. had to switch to Xeoma instead (works with H.264 as well as (M)JPEG). it wouldn’t find the camera at first but then I figured it out, works OK now
