ZME_WCD2 WallC controller for Vera_Lite
I tried to configure the new ZME_WCD2 WallC Controller in the VERA Lite, Vera is recognizing the controller, but i’am not succeeded to let it work with scenes.
It has to to with the configured setting, i tried a lot of settings, inspired with this toppic: [url=http://www.vesternet.com/resources/application-notes/apnt-44#.U-fDJWNeqs8]http://www.vesternet.com/resources/application-notes/apnt-44#.U-fDJWNeqs8[/url]
i see the buttons are working, green light and the LastSceneId is set when pushed the button, but the sl_SceneActivated is not set!, so thats the problem, this setting is need to add triggers in a scene with this id.
See attached images.
Has anyone an idea for me to make it work?
APNT-44 is for the older Z-Wave.me wall controller, for the newer version (BJ2000) you’ll need to refer to APNT-69 - http://www.vesternet.com/resources/application-notes/apnt-69
Hope that helps,
Martyn
Thanks for quick response, sure it helps with the right documentation :), it works now.
Can’t get it to work with UI7… HOW HOW HOW HELP!!
Here I also can’t make it work with UI7.
Any luck?
The same for me. Does nobody know a solution?
I have got everything to work as per Vesternets instructions a few post above on UI7.
What does not work for you?
might help: http://forum.micasaverde.com/index.php/topic,32498.msg296706.html#msg296706
