I have an issue with already discussed KFOB… ZME KFOB2 working in Zwave Plus standard.
I was trying to add this as scene controller.
At the beginning the procedure looks standard - but I never managed this to work as expected.
Second try was to follow the manual - step by step - from website http://support.betaalbare-domotica.eu/en/how-to-use-zwave-me-keyfob-in-scene-mode-with-ui7-2/
Step by step procedure looks logical and fine. But the effect is that KFOB is getting error: Failed at: Please wait! Getting secure classes
From my understanding the problem is with the communication - as the KFOB is not able to exchange security keys… or communicate to the end.
At the end it is not configured…
Any idea how to fix this - what should be changed?
As extra info - when the KFOB was added it was necessary to select Other Zwave Device from the menu - adding using ZME KFOB dialogue was not working.
I think this is just small issue in the connection wizard… probably it was prepared for version 1 of the KFOB.
Any idea what can I do to fix this…?
Thanks in advance
Michal
