Don’t know why I can’t ever find this information…
Setup worked just fine
Now, I want to have it turn on the lights for 5-10 minutes upon detection. It should stay on if it keeps sensing. Problem is there is some sort of delay before it starts sensing again and it is longer than 10 minutes. Where do I set that parameter?
Currently it turns on the lights correctly, turns then off in 10 minutes, but won’t sense again for another 15 minutes or more (not sure exactly how long)
How did you configure the 10 minutes; as part of the scene?
I have a ZIR000 that I use to trigger lights through Vera. My unit resets itself after 3 minutes. I set the scene so that the lights stay lit for a minimum of 5 mins. So, as long as there is motion in the room, the lights do stay on.
Don’t know why mine reset in 3 minutes, and yours in 20 minutes. I didn’t configure any special settings on the unit or in the Vera related to the ZIR000.
I see. My guess is @markbannister has it configured through the scene as well.
You could also let the sensor’s ‘trip’ and ‘untrip’ events trigger an on and off scene, respectively. That’s how I have mine set up. AFAIK, for the ZIR000 there’s only one parameter that controls the delay. It’s parameter 18 ([tt]Device Options[/tt] → [tt]Configuration settings[/tt]). The value (in minutes) is in addition to a built-in 2-minute minimum.
I see. My guess is @markbannister has it configured through the scene as well.[/quote]
Yes using a scene. Thanks. In UI4 edit the device, Edit Device tab, Configuration settings, variable 18, 1 byte dec, value is time in minutes (seems to be minutes anyway)
Works as designed it seems but not as expected.
Scene never “resets” and starts. Over. That is I have a scene triggered to stay on for ten minutes. I thought if the sensor kept seeing movement the scene would reset and stay on.
Any way around this"
Normally, to maximize battery life, the sensor would send a single On command when it detects motion, and then a single Off command if no motion is detected for the programmed number of minutes. So if the sensor keeps seeing motion all the time, it won’t send an Off or a new On.
You could use 1 scene that is triggered by the sensor’s trip (i.e. motion) to turn on the lights, and 1 scene that is triggered by the sensor’s untrip (i.e. no motion for the set number of minutes) to turn off the lights.
I don’t have this sensor, but my ca9000s have ‘pulse 5min 15min etc’ setting options. I only use the pulse mode, and trigger a scene when the pulse on is received. I ignore the sensor’s off command.
The scene is set to ‘after xx min turn off’. Repeated pulse triggers (motion) restarts the scene and resets the off timer.
I don’t have this sensor, but I thought in pulse mode the ‘no-motion’ delay is almost instant, just a few seconds maybe. That seems fine for ‘one-shot’ applications, like a hallway, to turn the lights on for a minute or so. But to keep the lights on in a room, like living room or office space, I think it would be generating a lot of needless On/Off commands, which drains the batteries, takes airtime, and keeps Vera busy.
All depends on how much motion you’re actually generating, but I think you’re relying on the sensor not seeing any motion for a brief period at least once within the ‘after xx min turn off’ interval.
Hmm, the timers do not restart as far as I can tell.
OK, that works. Trip on turns on lights. Un-tripped sets another scene that times out in a few minutes to turn off lights.
This is in our kitchen gets tripped a good bit. I’m going to get rid of the batteries and use a DC adapter.
Thanks for everyone’s comments and help.
Hmm, the timers do not restart as far as I can tell.[/quote]
I’m pretty sure they do. I did some tests when I first got my motion sensors.
If delayed actions did not get reset upon re-triggering a scene, that would cause all kinds of issues.
here is what I found when using tripped and Not tripped scenes
Sensor trips with motion and I turn on the lights and keep them on
After 2 minutes the (parameter 18) times out and the “not tripped” scene triggers. This is even if the sensor is showing as seeing motion. This is either a WAD or bug. Who Knows
The work around is to to make a more complicated not tripped scene
The not tripped does this:
Leave lights unchanged and then after three minutes turn them off
If during that three minute time the motion sensor triggers the tripped scene, that seems to reset the not tripped timers.
BTW the not tripped scene must at first make no changes to the lights or else it could turn lights on that were already off.
How did the sensor show it is seeing motion? As long as the sensor is seeing motion, the red LED won’t come on and you wouldn’t see any updates on the Dashboard.
Right, the “red man” is staying red and running on the dashboard.
Now that I’ve posted the above fix I don’t think it’s working. I ran simple tests to check and it seemed to work but now in the real world something else is going on.
Right, the “red man” is staying red and running on the dashboard.[/quote]
The running red guy only indicates that the sensor was tripped, i.e. the sensor saw motion ‘once’ and sent Vera a ‘tripped’ event. Thus, it will always stay running until the sensor ‘untrips’ (i.e. is not tripped anymore).
So, if you see the ‘not tripped’ scene running (i.e. the lights go off), it means the sensor did not see motion anymore and sent Vera an ‘untrip’ event.
In other words, it should work as you expected:
- Sensor sees motion > send ‘tripped’ to Vera > run ‘tripped’ scene / turns lights on / running red guy.
- Sensor keeps seeing motion > nothing sent to Vera > lights stay on / red guy keeps running.
- Sensor stops seeing motion for set period > send ‘not tripped’ to Vera > run ‘not tripped’ scene / turns lights off / standing blue guy.
[quote=“oTi@, post:17, topic:168643”]The running red guy only indicates that the sensor was tripped, i.e. the sensor saw motion ‘once’ and sent Vera a ‘tripped’ event. Thus, it will always stay running until the sensor ‘untrips’ (i.e. is not tripped anymore).
- Sensor stops seeing motion for set period > send ‘not tripped’ to Vera > run ‘not tripped’ scene / turns lights off / standing blue guy.[/quote]
What is happening (it seems) is that the sensor sends the not tripped not matter what after the parameter 18 timeout period.
Understood; but did you try that by actively walking around in front of the sensor and did not see the red LED light up? Did it re-trip right away?
Understood; but did you try that by actively walking around in front of the sensor and did not see the red LED light up? Did it re-trip right away?[/quote]
No
