Hello,
is it known when Vera will support Zigbee 3.0 protocol?
There are lot of new Zigbee 3.0 interesting devices and it is pitty that Vera does not support it.
Thank you
Thomas
Hello,
Thank you
Thomas
Hi @matoni555,
Ezlo Plus and Ezlo Secure already supporting ZigBee 3.0
Just curious which ZigBee 3.0 devices are you planning to use ?
Hi @Oleh,
really? Where I can find information about this support? I tried to find it on getvera.com and this forum I did not found any info about it.
I want to use some power plugs with Zigbee 3.0
Vera Plus and Vera Secure don’t support Zigbee 3.0.
Oleh is referring to the new Ezlo hubs that are being developed and will eventually replace the Vera line of hubs.
Which begs the question, if you update your Vera Plus or Secure with the Ezlo firmware when available for those hubs, do they then support Zigbee 3.0?
Or is it a hardware chip thing rather than just firmware.
Pretty sure this is the problem. Just like the lack of ZLL support for lights. All the programming in the world won’t fix ZLL.
