Good day guys,
I’m hopeless. I have been using ZeraBrand for quite a while and must admit it’s THE tool but latelly, I debug my code, make sure every run smoothly, copy everything over VERA. For some reason VERA gives me a LuaInterface::CallFunction_Scene Scene 105 failed attempt to call a nil value. I immediatlly run the same code within ZeraBrand, no error.
I’m experiance that behavior in most of the scene I developped with ZeraBrand (has nothing to do with ZeraBrand)
Any thoughts?
–Version 1.0.22
– IDEAS AND FEATURE TO DEVELOPPED
– Close fireplace lights at the same time if luxlevel > 140
function myerrorhandler( err )
addLog( "ERROR AutoLight: ".. err )
function inTimeframe(pStart, pEnd)
local hS, mS = string.match(pStart,“(%d+)%:(%d+)”)
local mStart = (hS * 60) + mS
local hE, mE = string.match(pEnd,“(%d+)%:(%d+)”)
local mEnd = (hE * 60) + mE
local tNow = os.date(“*t”)
local mNow = (tNow.hour * 60) + tNow.min
if (mNow >= mStart) and (mNow <= mEnd) then
return true
else
return false
function addLog(log)
local filewrite = io.open(“/var/log/cmh/zst.txt”, “a”)
local datetime = os.date(“%c”)
filewrite:write(datetime .. " | “.. log..”\n")
filewrite:flush()
filewrite:close()
function getGlobalValue(variableID,ID)
local tmpValue = luup.variable_get(“urn:upnp-org:serviceId:VContainer1”,variableID, ID)
if tmpValue == nil then
addLog("PRESENCE: Found a nil value, VariableID: “..variableID..” ID: "..ID)
else
return tonumber(tostring(tmpValue))
function setGlobalValue(variableID,value)
– variableID has to be like newVariable1-5;
luup.call_action(“urn:upnp-org:serviceId:VContainer1”, “SetVariable”..variableID, {[“newVariable”..variableID] = value}, 977)
function FlagOff()
luup.call_action(“urn:upnp-org:serviceId:VSwitch1”, “SetTarget”, {newTargetValue = “0”}, 951)
setGlobalValue(“3”,“0”)
function closeLight(LightID)
luup.call_action(“urn:upnp-org:serviceId:Dimming1”,“SetLoadLevelTarget”,{ newLoadlevelTarget = “0”}, LightID)
function setLightLevel(upLevel,LightID)
– Only send the command if do not equal the upLevel asked.
local currentLevel = tonumber(tostring(luup.variable_get(“urn:upnp-org:serviceId:Dimming1”,“LoadLevelStatus”, LightID)))
if currentLevel ~= upLevel then
luup.call_action(“urn:upnp-org:serviceId:Dimming1”,“SetLoadLevelTarget”,{ newLoadlevelTarget = upLevel}, LightID)
addLog("AUTOLIGHT setlightLevel set light: “..LightID..” to "..upLevel)
function changeHouseMode()
– Change house mode from sleep to 1 if motion is detected anywhere downstairs.
if inTimeframe(“6:15”,“12:00”) == true then
if getHOUSEMODE() == “3” then
luup.call_action(“urn:micasaverde-com:serviceId:HomeAutomationGateway1”,“SetHouseMode”, {Mode = “1”}, 0)
addLog("AUTOLIGHT: Changing the house mode from Night to Home")
function dimLight(upLevel,LightID)
local currentLevel = 0
local setlightLevel = 0
currentLevel = tonumber((luup.variable_get("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus", LightID)))
addLog("AUTOLIGHT dimLight upLevel: "..upLevel.." LightID: "..LightID.." currentLevel: "..currentLevel.." setlightLevel: ".. setlightLevel)
if (tonumber(currentLevel) < tonumber(upLevel) or (tonumber(currentLevel) > tonumber(getGlobalValue("Variable3",977)))) then
setlightLevel = tonumber(getGlobalValue("Variable3",977))
-- if upLevel is smaller then setlightLevel, use upLevel as the max.
if setlightLevel > upLevel then
setlightLevel = upLevel
if setlightLevel >= currentLevel then
luup.call_action("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget",{ newLoadlevelTarget = tostring(setlightLevel)}, LightID)
addLog("AUTOLIGHT setlightLevel TRUE set light: "..LightID.." to "..setlightLevel)
else
-- IF autolight wants to reduced the light level based on the LUX. Only allow if was at the previous setting.
-- In other words, if users changed the light setting, leave it as is.
if currentLevel == 10 or currentLevel == 20 or currentLevel == 30 or currentLevel == 40 or currentLevel == 50 or currentLevel == 60 or currentLevel == 70 or currentLevel == 80 or currentLevel == 90 or currentLevel == 100 then
luup.call_action("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget",{ newLoadlevelTarget = setlightLevel}, LightID)
addLog("AUTOLIGHT setlightLevel set light: "..LightID.." to "..setlightLevel)
function getHOUSEMODE()
local housemode = tostring(luup.attr_get “Mode”)
return housemode
function motionTrippedDelay(sensor,delay)
– Return true if motion is not tripped and passed delay
local SES_SID = “urn:micasaverde-com:serviceId:SecuritySensor1”
–Check to see if movement somewhere, if not, abord procedure.
local tripped = luup.variable_get( SES_SID, “Tripped”, sensor) or “0”
local lastTrip = luup.variable_get( SES_SID, “LastTrip”, sensor) or os.time()
if (tripped == “1” or (os.time() - lastTrip <= delay)) then
return true
else
return false
function AutoLightMain()
local LuxLevel = tonumber(tostring(luup.variable_get(“urn:micasaverde-com:serviceId:LightSensor1”,“CurrentLevel”, 897)))
–If blinds was closed based on temp and time, flags represent that dining room was closed.
local closeDiningWeather = tostring(getGlobalValue(“Variable2”,1001))
– LuxLevel must be under 140 or
– if closed the blind in the dining room, use a new threshold
– or if weekdays and no mouvement.
local DELAY = 120 – Seconds
– Sensor 990 = Kitchen
– Sensor 895 = Dining room
– Sensor 1003 = Cam Entrance
– Sensor 835 = Cam Kichen
local kitchenNoMouv = motionTrippedDelay(1012,DELAY)
if (kitchenNoMouv == true) then
– Mouvement detected, reset closeLightNoMouv flag
luup.call_action(“urn:upnp-org:serviceId:VContainer1”, “SetVariable3”, {[“newVariable3”] = “0”}, 986)
addLog(“AUTOLIGHT Mouvement detected, reset closelightnomouv flag”)
elseif (kitchenNoMouv == false) then
– Close lights if no mouvement and weekdays within a time frame
addLog(“AUTOLIGHT no Mouvement detected”)
local currentWeekDay = os.date("%A")
if (currentWeekDay == "Monday" or currentWeekDay == "Tuesday" or currentWeekDay == "Wednesday" or currentWeekDay == "Thursday" or currentWeekDay == "Friday") and inTimeframe("8:00","16:00") == true then
addLog("AUTOLIGHT no Mouvement detected within weekdays and between 8 to 16")
local CloseLightNoMouv = tonumber(tostring(getGlobalValue("Variable3",986)))
--if no mouvement is detected and CloseLughtNiMouv is on meaning that the ligths has been turnedoff. Abord procedure
if CloseLightNoMouv == 1 then
addLog("AUTOLIGHT abord procedure, lights seem to be closed.")
return
--CloseLightsNoMouv
if CloseLightNoMouv == 0 and inTimeframe("8:00","15:30") then
luup.call_action("urn:upnp-org:serviceId:VContainer1", "SetVariable3", {["newVariable3"] = "1"}, 986)
CloseLightNoMouv = 1
if kitchenNoMouv == false then
addLog("AUTOLIGHT no Mouvement close all the lights")
-- no motion in kitchen
--[[ Home Theater --]]
--[[ ht_FrontLight --]]
closeLight(199)
--[[ ht_MiddleLight --]]
closeLight(201)
--[[ Kitchen --]]
--[[kit_Lights --]]
closeLight(16)
--[[kit_Hallway_Lights --]]
closeLight(979)
--[[ kit_island --]]
closeLight(54)
--[[ Power Room --]]
--[[ pr_room --]]
closeLight(19)
--Lights in dining room
--[[ Dining Room --]]
--[[DR-TableLights --]]
closeLight(186)
--[[ DR-PotsLights --]]
closeLight(187)
addLog("AUTOLIGHT Close lights in Kitchen, no mouvmement.")
return
if LuxLevel >= 140 or (closeDiningWeather == “1” and LuxLevel > 25) then
–IF LUX WHEN OVER 90 NEED TO CLOSE THE LIGHTS THAT WAS TURNED ON.
if tonumber(getGlobalValue(“Variable3”,977)) > 0 then
closeLight(186)
closeLight(187)
closeLight(199)
closeLight(201)
closeLight(16)
closeLight(979)
closeLight(54)
closeLight(19)
closeLight(27)
closeLight(25)
closeLight(135)
closeLight(30)
closeLight(32)
closeLight(202)
closeLight(991)
closeLight(979)
addLog(“AUTOLIGHT Close all lights, not dark enough.”)
addLog(“AUTOLIGHT Not enough dark to launch.”)
return false
– Check if motion in Kitchen and dining room.
–bypass if new person arrived (variable4) > then 0 will have the VSswithID
– Start process in housemode is HOME or NIGHT, if night, only lit up first floor only is new person arrived.
if (tostring(getHOUSEMODE()) == “1”) or (tostring(getHOUSEMODE()) == “3” and tonumber(getGlobalValue(“Variable4”,977)) > 0) then
–Open Lights after 4:00
local startTime = “16:30”
local hour = tonumber( startTime:sub( startTime:find(“%d+”) ) )
local minute = tonumber(startTime:sub(-2))
startTime = hour * 100 + minute
local currentTime = os.date(“*t”)
currentTime = currentTime.hour * 100 + currentTime.min
if startTime <= currentTime then
–Open lights kitchen
–Island
setLightLevel(100,16)
setLightLevel(50,54)
LuxLevel = tonumber(LuxLevel)
--Keep the old light level
setGlobalValue("2",getGlobalValue("Variable3",977))
--Based on the sky condition, if sunny and clear, use the following value else, lower ones.
--local currentSkyCondition = tostring(getGlobalValue("Variable2",1000))
--if currentSkyCondition
local dayNight = luup.variable_get("urn:rts-services-com:serviceId:DayTime","Status",970)
if LuxLevel <=140 and LuxLevel >= 75 then
--level 1
if dayNight == "0" then
setGlobalValue("3","5")
else
setGlobalValue("3","10")
elseif LuxLevel < 75 and LuxLevel >= 70 then
--level 2
else
setGlobalValue("3","20")
elseif LuxLevel < 70 and LuxLevel >= 65 then
--level 3
setGlobalValue("3","15")
else
setGlobalValue("3","30")
elseif LuxLevel < 65 and LuxLevel >= 60 then
--level 4
else
setGlobalValue("3","40")
elseif LuxLevel < 60 and LuxLevel >= 55 then
--level 5
else
setGlobalValue("3","50")
elseif LuxLevel < 55 and LuxLevel >= 45 then
--level 6
else
setGlobalValue("3","60")
elseif LuxLevel < 45 and LuxLevel >= 25 then
--level 7
else
setGlobalValue("3","70")
elseif LuxLevel < 25 and LuxLevel >= 20 then
--level 8
else
setGlobalValue("3","80")
elseif LuxLevel < 20 and LuxLevel >= 15 then
--level 9
else
setGlobalValue("3","90")
elseif LuxLevel < 15 and LuxLevel >= 0 then
--level 10
else
setGlobalValue("3","100")
else
--Nothing for now.
setGlobalValue("3","0")
return
--Only close blinds if in the afternoon and open the fireplace lights.
startTime = "15:30"
hour = tonumber( startTime:sub( startTime:find("%d+") ) )
currentTime = os.date("*t")
if startTime <= currentTime and tostring(getGlobalValue("Variable3",977)) == "100" then
local sBlindDenBlind1 = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 969)
local sBlindDen12 = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 51)
local sBlindLR12_Den = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 49)
local sBlindMB_Blind = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 53)
local sBlindHU_Blind = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 175)
if sBlindDenBlind1 == "0" then
-- must close the blind
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 969)
if sBlindDen12 == "0" then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 51)
if sBlindLR12_Den == "0" then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 49)
if sBlindMB_Blind == "0" then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 53)
if sBlindHU_Blind == "0" then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 175)
--Open fireplace lights
local sFireplaceLight = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 991)
if tostring(getGlobalValue("Variable3",977)) ~= tostring(getGlobalValue("Variable2",977)) and sFireplaceLight =="0" then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" },991)
--Patch, check if kitchen pot lights are on, if so, abord procedure, looks like the lights are on.
local currentLevel = tonumber((luup.variable_get("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus", 16)))
local currentLevelHU = tonumber((luup.variable_get("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus", 25)))
if tostring(getGlobalValue("Variable3",977)) == tostring(getGlobalValue("Variable2",977)) and (currentLevel > 0 and dayNight == "0") or (currentLevel > 0 and currentLevelHU > 0 and dayNight == "1") then
-- SHOULD CHECK THE LIGHT STATUS TOO. I HAD TO RESET THE FLAG IT TOUGHT THAT IT WAS A THE RIGHT MODE.
return
--flag on
luup.call_action("urn:upnp-org:serviceId:VSwitch1", "SetTarget", {newTargetValue = "1"}, 951)
addLog("AUTOLIGHT VSSwitch ON")
dimLight(10,186)
dimLight(40,199)
dimLight(40,201)
--[[ Kitchen --]]
--[[kit_Lights --]]
dimLight(100,16)
dimLight(100,979)
dimLight(50,54)
--[[ pr_room --]]
dimLight(20,19)
-- Only light up the second floor if NOT in goodnight mode and new person arrived
if getHOUSEMODE() == "3" then
return
dimLight(100,187)
--THIS PART WON'T BE EXECUTED IF HOUSE IS IN GOODNIGHT
-- Only open lights on the second floor within that time frame
--MUST CHECK THE SEASON AND ADAPT THE TIME (16HRS) DO NOT WORK FOR NOVEMBER
local pStart = "16:00" -- Start of time period
local hS, mS = string.match(pStart,"(%d+)%:(%d+)")
local tNow = os.date("*t")
if (mNow >= mStart) then
-- If later then pStart, open lights
--[[ Highway upstairs --]]
--[[ hu_potLight_Zak --]]
dimLight(100,27)
--[[ hu_PotLights --]]
dimLight(100,25)
--[[ hu_stairLight --]]
dimLight(20,135)
--[[ Master Bed --]]
--[[ mb_Ceiling --]]
dimLight(40,30)
--[[ mb_DadaBedSide --]]
dimLight(100,32)
--[[ mb_MamaLight --]]
dimLight(100,202)
local checkmouv = motionTrippedDelay(1012,400)
if checkmouv then
– Check if should change the house mode from sleep to home
local status = xpcall( changeHouseMode, myerrorhandler )
–Only start the process if not in GoodNight
if getHOUSEMODE() == “1” or (getHOUSEMODE() == “2” and
tonumber(getGlobalValue(“Variable4”,977)) >0) or (getHOUSEMODE() == “3” and
if tonumber(tostring(getGlobalValue(“Variable4”,977))) > 0 then
addLog("AUTOLIGHT launch with: Housemode= ".. getHOUSEMODE() .. " New person arrived ID: ".. getGlobalValue(“Variable4”,977))
local status = pcall(AutoLightMain)
if (not status) then
luup.log(“AUTOLIGHT:Error calling: AutoLight”)
addLog(“ERROR AUTOLIGHT”)
