Im in Australia and have just purchased the above IR controller. ( Z-Wave Home Automation Australia | Best Smart Home Devices! )
I have read through this forum (and others) but I am struggling.
Has anyone installed this into a vera 3 unit especially trying to control a Fujitsu Split Aircon
I?m trying to config it with parameter 27 ? data 2 DEC ? and all the Fujitsu codes but nothing works.
I believe the Vera unit has the device included fine and seems to be transmitting z wave requests but the IR doesn?t appear to connect to a Fujitsu split.
Im reluctant to go down the learning mode path as I believe the Aircons Im running are fairly common (at least in Aus) and Im sure someone could shed some light on the issue.
thx hopefully
