Hello everybody,
In Z-Wave settings by default is Master SIS:NO.
Do you now how to change role z-wave settings to Master SIS:YES ???
Thanks in advance ![]()
Hello everybody,
With the new z-wave firmware 3.20 this is normal as it doesn’t support secondary inclusion controllers any more. This is the same on the V2 and the V3, and if you want to use a secondary inclusion controller then you will need to revert back to the 2.78 version.
In reality the “NO” it displays under role for SIS, should be labeled as N/A really to avoid this confusion!
Hi Strangely,
Thank you so much for the clarification ![]()
