Z-Wave Recessed Door Sensor
Does anyone know of a Z-Wave Recessed Door Sensor? Obviously there are a lot of sensors that attach to the outside of the door, however I am looking for one a bit more discrete. I know that security systems have wireless recessed door sensors, however I am trying to avoid having to setup a a full blown security system such as DSC. If no recessed version, is there a unit that see the wireless security version that will convert to Z-Wave?
The Everspring SM103 has a contact input to which you could connect a conventional door sensor. You’d have to find somewhere to mount the SM103, but this could be a few feet away from the door if necessary. I’ve used this arrangement with an outside gate; a conventional recessed sensor is mounted in the frame of the gate with the magnet in the gate itself. The wire from the sensor then passes through a wall and is connected to a SM103 mounted on the other side.
Thanks for the heads up!
