I’ve been experimenting with the device z-wave options with my 3 ZIR000 motion sensors for setting config #18 (idle offset). Still not sure if it is programming correctly. I clicked on “add configuration”, then defined the following:
Variable Data Size Desired Value
18 1 byte dec 8
According to the manual, the setting takes a value between 0 - 255. This should adjust the default idle off from 2 minutes to 10 minutes. It seems to be working for the hallway sensors. Still testing the kitchen sensor which doesn’t seem to be responding anymore.
I also noticed that if I try to program the parameter without polling first, it fails to program. Is this the intended behavior?
