huwu
September 5, 2009, 1:29pm
#1
Has anybody a hint how I can heal this situation?
My dongle is constantly lighted, what also means that no Z-Wave command is possible - the network is down. Normally I can clear this situation by unplug/plug the dongle. It than starts blinking and everything is ok for the next few hours. But now - this thing is solid blue lighted. Nothing helps. Not unplug/plug, not reboot Vera, not pushing the dongle’s button.
I need some help!
I know you’ve also read the “Dongle Replacement Policy” post under Official Announcements, but also check out:
http://forum.micasaverde.com/index.php?topic=1618.0
Sounds like you could use a replacement dongle.
huwu
September 5, 2009, 2:21pm
#3
Thank you LibraSun. I should have said, that I own a two weeks old replaced .78 dongle…
huwu
September 5, 2009, 2:23pm
#4
The question is: How can I restart the dongle? Or… How long lasts the internal battery?
We mulled over these questions last month:
http://forum.micasaverde.com/index.php?topic=340.0
The battery question remains open, in my opinion, since MCV hasn’t given any lifetime estimates.
Hope you get your dongle situation ironed out.
huwu
September 5, 2009, 2:37pm
#6
Yes. that post:
http://forum.micasaverde.com/index.php?topic=1618.msg5491#msg5491
describes probably my problem as #2 . But there seems not to be a solution or workaround.
huwu
September 5, 2009, 2:41pm
#7
I found that little hole on the dongle’s back side. That is the reset-button. Two seconds after pushing the button everything was fine…
