This is a reference to basic Z-Wave routing options since version 1.1.1245 offers many options with all kinds of effects.
A little warning, im used to point to existing documentation as much as i can, to prevent duplicate information and provide an easy single point of update when certain information changes.
This thread was inspired by some users who had/have issues with the new way of routing available as of version 1.1.1245. Also the new Z-wave firmware version add mutliple options to control manual and automatic routing.
As a starting point i recommend these two threads on the wiki:
http://wiki.micasaverde.com/index.php/Migrate_To_Z-wave_version_452
http://wiki.micasaverde.com/index.php/Heal_Network
The 1.1.1245 section of this page provides more info on issues tackled with version 1245:
http://wiki.micasaverde.com/index.php/Release_Notes.
Many users have a mix of mains and battery powered devices. The battery powered devices go into “sleep” mode when not in use and only awake on events/triggers or on certain intervals to save batteries.
The biggest problem users run into are:
- Automatically reconfiguring devices based upon detected devices (altering the routing information for devices)
- Battery powered devices are not detected during automatic heals (and therefore dropped from the routing table)
- Users get lost in the many tickboxes and their functions.
Resulting in unwanted /automatically updated routing information in devices that is not in all cases consistent with the meshed network you may have built for your z-wave network.
I would like to reference these threads:
http://forum.mios.com/index.php?topic=6891.0 (also providing solutions)
Descriptions of Vera behavior:
- http://forum.mios.com/index.php?topic=6879.0
- http://forum.mios.com/index.php?topic=6887.0
- http://forum.mios.com/index.php?topic=6809.0
- http://forum.mios.com/index.php?topic=6813.0
Current available settings in the options tab of your z-wave device are:
[ul]1. “By default MiOS should automatically configure devices”
When ticked, this option will reconfigure devices automatically and rewrite routing information
(see also repair tab option 1 as described below)
“Use MiOS routing instead of Z-Wave (requires 4.5)”
Overrules normal Z-wave routing by MiOS model as introduced in version 1.1.1245
This option will also do automated healing of your network around 2am local time, but only if Vera finds broken routes during the day. -
“Limit neighbors to Z-Wave discovery (requries MiOS routing)”
Related to 2. This will actually limit the neighbours in your routing to the neighbours discovered when a “heal” is performed. Leave unchecked when you want full routing options available (from historically discovered devices.[/ul]
Current available settings in the repair tab of your z-wave device are:
[ul]1. “Re-configure all the devices when done.”
This will actually overwrite routing information existing in your device when checked
- “Only update MiOS routing (overrides other settings)”
This will leave existing information intact but will update MiOs parameters. Exact inner workings are not yet documented (as far as i could find)[/ul]
So if you have issues with routing or similar experiences as described by others in the threads i referred to, hopefully this will give some guidance on how to set your routing.
Henk
