Hi i was wondering if anyone else has had this issue when i add Z-Wave Fibaro Universal Dimmer 2 250W it adds 3 devices one to control the light and then two other devises dose anyone know why and how to fix this as it makes my dash board look messy and confusing for my other half?
this has to do with “how” vera interpretes the Zwave device. Vera needs to make this template. So 1st step is to contact Vera support and ask them to make a correct implementation for this device.
Else, if you have a working functionality on 1 device, you can hide the other with luup code by finding the correct device ID(s). I can copy past the code here, but it might be better to search the forum to overcome double posting.
On the latest UI7 firmware they are no more…!!! I just have the one slider and switch for all my dimmer 2 devices.
Previously I had the 2 extra sliders and switches. I’m guessing it was something to do with the 2 switch inputs, S1 and S2?
[quote=“RichDC, post:3, topic:195085”]On the latest UI7 firmware they are no more…!!! I just have the one slider and switch for all my dimmer 2 devices.
Previously I had the 2 extra sliders and switches. I’m guessing it was something to do with the 2 switch inputs, S1 and S2?[/quote]
Contact support…
