I hope this will be the best forum for this question. This is an electrical connection question.
I recently bought a GE Z-wave Duplex Receptacle (Lowe’s Iris 45636) to replace a ceiling outlet in my garage (to control a garage door opener, but that’s beyond the scope of this question).
The old receptacle had 5 wires (2 blacks, 2 whites, 1 ground) attached to it wherein my Z-wave receptacle only has 3 (black, white, ground). I’m guessing the receptacle I’m replacing still has other receptacles/switches connected to it downstream and in series.
Question: Can I simply connect the 2 existing black wires to the new receptacle’s black wire, connect the 2 existing whites to the new white wire, then ground to ground?
Thanks!
