I’m compiling a thread of my (and others) experiences with Z-Wave dimmers and the bulbs. I’ve found success getting LED bulbs to work with Z-Wave dimmers however I have hit some issues with certain bulbs (rather than the dimmers themselves) on flickering / not turning off. Feel free to add your experiences and I’ll try to add it to the main topic. All of the dimming estimates are subjective.
GE/Jasco 46506 (ZW3001-WCS) – 2 wire dimmer:
Works in the following configurations (multiple bulbs are in parallel):
1x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 0-100% dimming
2x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 0-100% dimming
3x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 0-100% dimming
4x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 0-100% dimming
Does not turn off when switch is off:
1x - Utilitech A19 13.5W 3000K LED Bulb (Lowes)
2x - Utilitech A19 13.5W 3000K LED Bulb (Lowes) – In addition, dimming behavior was inconsistent – low dimming levels would result in the bulb full on.
Monster IWD600 (Should be similar to Leviton VRI06-1LZ) - 2 wire dimmer
1x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 15-100% dimming
2x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 15-100% dimming
3x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 10-100% dimming
4x - Ecosmart A19 8.6W 3000K LED Bulb (Home Depot) - 5-100% dimming
Mostly works in the following configuration (multiple bulbs are in parallel):
2x - Utilitech A19 13.5W 3000K LED Bulb (Lowes) - 5-100% dimming, however flickers when dimmer is set to 100%. Works perfectly at 95% dimming.
Bulb Info
Ecosmart A19 8.6W LED Bulb (Home Depot) - 3000k - 430 Lumens - 180 degree angle - Uses an array of two LEDs
http://www.homedepot.com/buy/lighting-fans/light-bulbs/ecosmart/led-a19-40-watt-equivalent-light-bulb-39632.html
Utilitech A19 13.5W LED Bulb (Lowes) - 3000k - 800 Lumens - 300 degree angle - Uses an array of 5 LEDs
http://www.lowes.com/pd_338931-75774-LA19/OM800/LED_4294801193
Spreadsheet Info
I’m pulling together a google docs spreadsheet with this information (and more summarized):
