Hello,
I have been researching this problem but I haven’t been able to get it fixed. I have also logged a call with support almost a week ago but haven’t heard anything. Would really love to get everything working again. A less than two weeks ago my z-wave devices started to respond much slower and sometimes not at all. I didn’t change much except I added one device (an Arduino sensor from the MySensors plugin). I had previously had other arduino sensors connected for a long time (you’ll see one in the logs) with no issues. I have since tried removing the added device and restoring from two different backups but those things did not help. Would someone mind taking a look at the snippet of text from my log file to see if anything can be figured out from it? I am at a loss as to what to try next.
02 03/27/14 19:27:53.568 ZWaveSerial::GetFrame 0x2c18af58 timed out now 0 m_listGetFramePending 0 <0x2c18b680>
02 03/27/14 19:27:53.568 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2c18b680>
01 03/27/14 19:27:53.569 ZWJob_PollNode::Run job job#25 :pollnode #6 dev:7 (0x12ae800) N:6 P:100 S:1 ZW_Send_Data to node 6 failed 1 req 0xdbd1b0/1 abort m_iFrameID 0 <0x2c18b680>
02 03/27/14 19:27:53.569 ZWJob_PollNode::PollFailed job job#25 :pollnode #6 dev:7 (0x12ae800) N:6 P:100 S:1 node 6 battery 0 <0x2c18b680>
06 03/27/14 19:27:53.570 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Poll failed now: Poll failed #hooks: 0 upnp: 0 v:0x1005600/NONE duplicate:1 <0x2c18b680>
04 03/27/14 19:27:53.571 <0x2c18b680>
02 03/27/14 19:27:53.571 JobHandler::PurgeCompletedJobs purge job#25 :pollnode #6 dev:7 (0x12ae800) N:6 P:100 S:2 pollnode #6 1 cmds status 2 <0x2c18b680>
02 03/27/14 19:28:17.103 ZW_Send_Data node 24 NO ROUTE (nil) <0x2c18b680>
02 03/27/14 19:28:23.157 ZWaveSerial::GetFrame 0x2c18af58 timed out now 0 m_listGetFramePending 0 <0x2c18b680>
02 03/27/14 19:28:23.157 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2c18b680>
01 03/27/14 19:28:23.158 ZWJob_PollNode::Run job job#26 :pollnode #24 dev:50 (0x10ad348) N:24 P:100 S:1 ZW_Send_Data to node 24 failed 1 req 0x10b7b60/1 abort m_iFrameID 0 <0x2c18b680>
02 03/27/14 19:28:23.159 ZWJob_PollNode::PollFailed job job#26 :pollnode #24 dev:50 (0x10ad348) N:24 P:100 S:1 node 24 battery 0 <0x2c18b680>
06 03/27/14 19:28:23.159 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Poll failed now: Poll failed #hooks: 0 upnp: 0 v:0x1005600/NONE duplicate:1 <0x2c18b680>
04 03/27/14 19:28:23.160 <0x2c18b680>
02 03/27/14 19:28:23.161 JobHandler::PurgeCompletedJobs purge job#26 :pollnode #24 dev:50 (0x10ad348) N:24 P:100 S:2 pollnode #24 1 cmds status 2 <0x2c18b680>
50 03/27/14 19:28:25.798 luup_log:27: Arduino: Set Var: 4;3;1;0;45.9 <0x2edcd680>
50 03/27/14 19:28:25.798 luup_log:27: Arduino: Setting variable 'CurrentTemperature' to value '45.9' <0x2edcd680>
50 03/27/14 19:28:25.798 luup_log:27: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 45.9, 56 <0x2edcd680>
06 03/27/14 19:28:25.799 Device_Variable::m_szValue_set device: 56 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 46.0 now: 45.9 #hooks: 0 upnp: 0 v:0xeec408/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.800 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970105, 56 <0x2edcd680>
06 03/27/14 19:28:25.800 Device_Variable::m_szValue_set device: 56 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970006 now: 1395970105 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.828 luup_log:27: Arduino: Set Var: 4;2;1;1;35.0 <0x2edcd680>
50 03/27/14 19:28:25.829 luup_log:27: Arduino: Setting variable 'CurrentLevel' to value '35.0' <0x2edcd680>
50 03/27/14 19:28:25.829 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HumiditySensor1,CurrentLevel, 35.0, 57 <0x2edcd680>
06 03/27/14 19:28:25.829 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:HumiditySensor1 variable: CurrentLevel was: 35.2 now: 35.0 #hooks: 1 upnp: 0 v:0xfa7328/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.831 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970105, 57 <0x2edcd680>
06 03/27/14 19:28:25.831 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970072 now: 1395970105 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.833 luup_log:27: Arduino: Set Var: 4;1;1;0;47.0 <0x2edcd680>
50 03/27/14 19:28:25.833 luup_log:27: Arduino: Setting variable 'CurrentTemperature' to value '47.0' <0x2edcd680>
50 03/27/14 19:28:25.833 luup_log:27: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 47.0, 58 <0x2edcd680>
06 03/27/14 19:28:25.834 Device_Variable::m_szValue_set device: 58 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 47.2 now: 47.0 #hooks: 1 upnp: 0 v:0xeec408/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.835 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970105, 58 <0x2edcd680>
06 03/27/14 19:28:25.836 Device_Variable::m_szValue_set device: 58 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970072 now: 1395970105 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.837 luup_log:27: Arduino: Set Var: 4;0;1;4;81653 <0x2edcd680>
50 03/27/14 19:28:25.837 luup_log:27: Arduino: Setting variable 'CurrentPressure' to value '81653' <0x2edcd680>
50 03/27/14 19:28:25.838 luup_log:27: Arduino: urn:upnp-org:serviceId:BarometerSensor1,CurrentPressure, 81653, 59 <0x2edcd680>
06 03/27/14 19:28:25.838 Device_Variable::m_szValue_set device: 59 service: urn:upnp-org:serviceId:BarometerSensor1 variable: CurrentPressure was: 81663 now: 81653 #hooks: 1 upnp: 0 v:0xf7b720/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:25.840 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970105, 59 <0x2edcd680>
06 03/27/14 19:28:25.840 Device_Variable::m_szValue_set device: 59 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970072 now: 1395970105 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
02 03/27/14 19:28:47.103 ZW_Send_Data node 25 NO ROUTE (nil) <0x2c18b680>
04 03/27/14 19:28:47.238 <0x2bd8b680>
50 03/27/14 19:28:58.838 luup_log:27: Arduino: Set Var: 4;3;1;0;45.7 <0x2edcd680>
50 03/27/14 19:28:58.838 luup_log:27: Arduino: Setting variable 'CurrentTemperature' to value '45.7' <0x2edcd680>
50 03/27/14 19:28:58.838 luup_log:27: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 45.7, 56 <0x2edcd680>
06 03/27/14 19:28:58.839 Device_Variable::m_szValue_set device: 56 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 45.9 now: 45.7 #hooks: 0 upnp: 0 v:0xeec408/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.839 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970138, 56 <0x2edcd680>
06 03/27/14 19:28:58.840 Device_Variable::m_szValue_set device: 56 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970105 now: 1395970138 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.868 luup_log:27: Arduino: Set Var: 4;2;1;1;34.9 <0x2edcd680>
50 03/27/14 19:28:58.868 luup_log:27: Arduino: Setting variable 'CurrentLevel' to value '34.9' <0x2edcd680>
50 03/27/14 19:28:58.869 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HumiditySensor1,CurrentLevel, 34.9, 57 <0x2edcd680>
06 03/27/14 19:28:58.869 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:HumiditySensor1 variable: CurrentLevel was: 35.0 now: 34.9 #hooks: 1 upnp: 0 v:0xfa7328/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.871 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970138, 57 <0x2edcd680>
06 03/27/14 19:28:58.871 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970105 now: 1395970138 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.872 luup_log:27: Arduino: Set Var: 4;1;1;0;46.7 <0x2edcd680>
50 03/27/14 19:28:58.873 luup_log:27: Arduino: Setting variable 'CurrentTemperature' to value '46.7' <0x2edcd680>
50 03/27/14 19:28:58.873 luup_log:27: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 46.7, 58 <0x2edcd680>
06 03/27/14 19:28:58.873 Device_Variable::m_szValue_set device: 58 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 47.0 now: 46.7 #hooks: 1 upnp: 0 v:0xeec408/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.875 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970138, 58 <0x2edcd680>
06 03/27/14 19:28:58.875 Device_Variable::m_szValue_set device: 58 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970105 now: 1395970138 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.876 luup_log:27: Arduino: Set Var: 4;0;1;4;81644 <0x2edcd680>
50 03/27/14 19:28:58.877 luup_log:27: Arduino: Setting variable 'CurrentPressure' to value '81644' <0x2edcd680>
50 03/27/14 19:28:58.877 luup_log:27: Arduino: urn:upnp-org:serviceId:BarometerSensor1,CurrentPressure, 81644, 59 <0x2edcd680>
06 03/27/14 19:28:58.878 Device_Variable::m_szValue_set device: 59 service: urn:upnp-org:serviceId:BarometerSensor1 variable: CurrentPressure was: 81653 now: 81644 #hooks: 1 upnp: 0 v:0xf7b720/NONE duplicate:0 <0x2edcd680>
50 03/27/14 19:28:58.879 luup_log:27: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1395970138, 59 <0x2edcd680>
06 03/27/14 19:28:58.880 Device_Variable::m_szValue_set device: 59 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1395970105 now: 1395970138 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2edcd680>
02 03/27/14 19:29:17.103 ZZZ-POLLING H1,C1,H2,C2,/1/1 <0x2c18b680>
02 03/27/14 19:29:17.104 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
02 03/27/14 19:29:19.398 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
06 03/27/14 19:29:19.727 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 67 now: 67 #hooks: 1 upnp: 0 v:0xeec408/NONE duplicate:1 <0x2bd8b680>
02 03/27/14 19:29:21.729 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
02 03/27/14 19:29:24.049 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
02 03/27/14 19:29:26.358 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
06 03/27/14 19:29:26.657 Device_Variable::m_szValue_set device: 3 service: urn:upnp-org:serviceId:HVAC_FanOperatingMode1 variable: Mode was: Auto now: Auto #hooks: 1 upnp: 0 v:0xec58b8/NONE duplicate:1 <0x2bd8b680>
02 03/27/14 19:29:28.659 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
02 03/27/14 19:29:30.958 ZW_Send_Data node 2 NO ROUTE (nil) <0x2c18b680>
Thanks,
Pete
