Z-wave button/switch with status indicator light ?
Does anyone use z-wave switches having a status indicator light?
I want to trigger a sleep-mode scene with a physical switch, but due non-tech use, it should have a indicator fo its own status (on/off)
Most switches/buttons i have found are just use the lights for coolness and less for functions :frowning:
Any recomentations ?
I have an outdoor one from duwi, no light when off, blue led is on when the light is on.
Also the Everspring I own have this, I just realise
oh thats good to know.
i ant a double switch but use only one for a real light … the other one to trigger a scene only thats why need the indication.
does the control light goes off if the switch has been flipped via the Vera ?
If you use a Leviton switch, it has a green indicator below the paddle.
Green on = switch off
Green off = switch on
GE switches are similar, however they do NOT support instant status, and Vera probably will not activate the scene immediately.
