I was wondering what devices people are use for to monitor air quality with their Vera?s? I have a water heated house and the CO2 gets a bit high when I?m sleeping in my bed room even with the door open. I would like to use some type of Z-wave CO2 sensor/Air Quality sensor with my vera to trigger my houses fan controls. Do you have any recommendations or suggestions?
Same. If CO2 gets around 800 ppm I have the fans/ventilation kick on. If it falls below 500 ppm, same items are turned off. Done by hooking them up to a zwave light switch and creating a scene.
Thank you for the feedback, Netatmo has a number of products at first I thought you were referring to the Netatmo healthy home coach? Which seems like what I’m looking for but when I did a searched for Netatmo plugin’s for the vera I only found a plugin for the Netatmo Weather Station? Does the Weather Station plugin work for the Netatmo healthy home coach as well?
