I have 2 Yale YDRD246 configured on my VeraPlus. The Vera is about mid-range distance from one to the other. However, I don’t know why the first one is completely reactive with the controler and the other one is not… I lock the door from inside, and the Vera controler don’t seem to receive the notifications. The parameters are the same and I have a lot of Z-Wave devices, so if they react as repeaters, the issue should not be the distance between them, right ?
What do you suggest ?
Thanks for your help !
