Yale touch screen with scene for each user
Finally I have installed my yale touchscreen.
Mounting and add to vera worked fine. My vera is 6 meters from my front door and including no needs batteries.
I have adding 4 pin codes and it was very easy and secure.
Now i need create a scene if user X enter with your pin code i need run a specific scene.
Has someone code for this? I think this needs a luup code.
Thanks in advance
You really need to do a search. This question has come up many times and I believe there are some limitations on the yale lock for certain events that do not work in the current firmware.
  • Garrett
sorry, but I thought that because if I add pin codes to my door lock in vera was easy to test …
if pin code is x then run this scene…
I will search.
thanks.
You really do not need Luup Code for this. I have mine setup to Disarm the Alarm when one of us enter our PIN code.
Create a scene and go to the Triggers → Select New Trigger → Select the Door Lock → Click Add → Select A Pin Code is Entered → Name the Trigger and select the index number for the Pin Code and that’s it. Now you can turn stuff on or off on the Devices Tab or go to the Advanced Tab to do something else. I use the Advanced tab to Disarm my Alarm System when one of use enter our pin code.
