Hello !!
yesterday when I came to home I try put my code but the panel do not lights on…
but if I try put the number touching where I think is your place the lock works and open…
someone with this problem ? and solution ?
thanks in advance…
Hello !!
thanks in advance…
I have a similar problem, in that the touchpad on my Yale lock is not responding or lighting up to touch at all. I’m just within the 1yr warranty period, so I contacted Yale and it looks like they will send a replacement lock, and you send back the defective lock.
Thanks Kyb2012…
this is one thing I do not want to read…
I will contact Yale…
regards…
