Greetings,
I have a Yale touchscreen deadbolt I just set up in my vera lite and I can’t seem to get the pin code restrictions to work.
The pin codes that I added via the vera interface all work, I just can’t restrict the times that they work.
When I try to set a weekly restriction, i get an error window that states “Failed to add weekly restriction”
Does anyone have experience you can bring to bear toward fixing this issue?
thanks
