Yale lock problems
I have a new Yale Real Living touchscreen lock. It works great with just a regular PIN but I can’t seem to get the restrictions working. I tried to do a weekly restriction for the housekeepers pin to only work on Tuesdays between 7am and 6pm. When I first did it and checked Tuesday, it set the pin up for Thursday. Then I checked both Thursday and Tuesday it showed up as working on Tuesday but the PIN doesn’t work. If I take the restrictions back off then the PIN works. Since this didn’t work, I setup notifications to let me know when the PIN was entered. This doesn’t work either. Any suggestions? I have the Vera Lite with the latest s/w and firmware.
I didn’t try the restrictions. But notifications are working for me. Assuming you did the inclusion correctly, make sure you do all the setup you need, then click Save, Reload, then click “configure node now” and give it time to configure itself. does it give any errors?
Hey,
I have the same setup, Yale Real Living Deadbolt (push-buttons) and VeraLite.
I am getting email notifications only when i open the door using mios.
But not getting any when a pin is entered (or a bad pin entered) on the lock itself.
It’s like the lock isn’t communicating back to the vera…
Did you get yours to work?
Hey guys, the yale lock is having trouble with the production build 408…
You should ask support for 420…
I also had some difficulty with restrictions… I want to have a daily schedule for midday for a specific code. Haven’t figured it out yet.
I’m getting my jam failure texts but not my invalid code text ???
