Anyone made an XML file for Enigma2 yet? I have a Vu+ Duo, but I am guessing it does not matter if its a Vu+ or a Dreambox
Hi GR, I do not have access to this device but if you learn all the codes using the iTach IP2IR and put them in a TXT file. I can create the XML file for you and upload it on Index of /xml
Just make sure you give me all the codes as listed on http://www.control-cube.com/xml/Du.xml
I wrote a plugin for such devices, which can be used to control the device over the net: http://forum.micasaverde.com/index.php/topic,10536.msg114922.html#msg114922
