local devnum =387
local endpoint =0402
luup.attr_set ("device_json","D_TemperatureSensor1.json",devnum)
luup.attr_set ("device_file","D_TemperatureSensor1.xml", devnum)
luup.attr_set ("device_type","urn:schemas-micasaverde-com:device:TemperatureSensor:1", devnum)
luup.attr_set ("category_num","17", devnum)
luup.attr_set ("subcategory_num","0", devnum)
luup.attr_set ("no_child_sync","0", endpoint)
luup.attr_set ("altid","84b50402", endpoint)
luup.attr_set ("id_parent","244", endpoint)
luup.variable_set("urn:micasaverde-com:serviceId:ZWaveDevice1", "NoChildren", "1", devnum)
luup.variable_set("urn:micasaverde-com:serviceId:HaDevice1", "ChildrenSameRoom", "0", devnum)
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "Reload", {}, 0)
Does this look correct ?
Device ID 387 is the main endpoint e.g the “Generic Zigbee Device” with the On / Off buttons.
0402 is the end point of a temperature sensor
Category 17, Subcategory 0 is for a temperature sensor
These two lines I am not so sure about
84b50402 is the altid of the current child endpoint named “Temperature Sensor”
244 is the parent ID of the main endpoint device e.g. the “Generic Zigbee Device” with the On / Off buttons
Also seems Zigbee devices are not listed when you do this:
If I search for the device numbers of these Zigbee devices they are not present in the generated device list.
These are the ID of the devices if I look at each of them in the UI7 GUI.
244 Not sure where this came from ? 244 is the parent of 387
387 - Generic Zigbee Device
388 - Temperature sensor child device
389 - Humidity sensor child device
EDIT: 244 is the number for the Zigbee Network when issuing this command:
http://VERA-IP:3480/data_request?id=lu_invoke
Yours was number 189 in your screen shots above.
