I have an x10 dimmer connected to my under cabinet lighting in my kitchen. Id like to be able to control it with my zwave veralite. Can I just plug my cm19a into the veralite’s usb just like the instructions for the insteon controller?
No. I suggest you look at this thread and what is on its way but uses CM11
http://forum.micasaverde.com/index.php/topic,23274.msg157948.html#msg157948
Thanks for the reply. I guess I’ll have to switch the dimmer to zwave
You can still use x10 but need to swap CM19 for CM11 but ZWave might be quicker and more reliable.
I’m writing up the docs for the new CM11 plugin. The way I designed it was so that someone should be able to easily create a CM17, CM19, or whatever version as long as they know the protocol and the devices and interfaces would remain the same.
Bruce
