X10 Dimmer with slilder
Is it possible to have x10 dimmer (marmitek lw12) added like ac dimmer with slider?
Now rfxtrx plugin adds my x10 lights as binarylights and i cannot dim those like ac dimmers.
[quote=“TomBear, post:1, topic:174979”]Is it possible to have x10 dimmer (marmitek lw12) added like ac dimmer with slider?
Now rfxtrx plugin adds my x10 lights as binarylights and i cannot dim those like ac dimmers.[/quote]
No, it is not possible becaiuse X10 does not manage a level but just a dim or bright feature. You can increase or decrease the level but not specify a precise level.
Yes some x10 dimmers support preset dimming. I just moved from Indigo automation (mac) system and it supports x10 dimmer level setting.
Not RFXtrx433 indeed.
[quote=“lolodomo, post:2, topic:174979”][quote=“TomBear, post:1, topic:174979”]Is it possible to have x10 dimmer (marmitek lw12) added like ac dimmer with slider?
No, it is not possible becaiuse X10 does not manage a level but just a dim or bright feature. You can increase or decrease the level but not specify a precise level.[/quote]
How can I increase or decrease the level on Marmitek LM12 (X10 lamp module) with RFXtrx ?
[quote=“emariu, post:5, topic:174979”][quote=“lolodomo, post:2, topic:174979”][quote=“TomBear, post:1, topic:174979”]Is it possible to have x10 dimmer (marmitek lw12) added like ac dimmer with slider?
How can I increase or decrease the level on Marmitek LM12 (X10 lamp module) with RFXtrx ?[/quote]
Bright / Dim buttons on the “remote” device are not working ?
Please open the advanced tab on your switch device and tell me what is the value of the attribute altid.
I tried the Dim and Bright buttons on the virtual remote,but NO action…
The altID on my X10 switch is "“LS/L1.0/A02"”
Please check the logs to check if a command is sent by the plugin. I imagine it will.
Are you sure that your physical devices is compatible with Dim/Bright ?
[quote=“lolodomo, post:8, topic:174979”]Please check the logs to check if a command is sent by the plugin. I imagine it will.
Are you sure that your physical devices is compatible with Dim/Bright ?[/quote]
Yes, I have a marmitek LM12 lamp module which I can dim/bright with my x10 remote control
So,how can I dim it with this plug-in ?
The Dim and Bright buttons should have the same effect as your remote buttons.
Maybe you should first check that Dim and Bright commands are working in the RFXCOM RFXmngr application. If they work, you should have the same behaviour from the plugin. If they don’t work for any reason, they will not work better from the plugin.
