Richard,
I am having an issue, I don’t know if the problem is the WOL plugin or PLEG, could you help me?
I am attaching two status, one follows the other one, as you can see, in both the condition named “fupan_sleep_when_empty” is false, for the first one is ok, but fur the second one is not ok, it should become true because the “music_all_off” condition becomes true and all the others where already true… but surprise… Fusam, which is a Ping WOL device, turns to be true in both reports, when it should be false in both reports… I am attaching a screenshot for that device…
The same thing happened tu me with the “fupan” which is another Ping WOL, and because the regular trigger was not being accurate, I decided to set it up as a property, which happens to be more accurate, but that should not happen, right?
Another weird thing is that when I removed the fupan trigger (because I was changing it for a property), I removed it from triggers without removing it from conditions and save and do all the Vera Dance. I was expecting and error from PLEG saying that the token FUPAN was invalid, and I didn’t get that message, although I reconfirmed that there was no input, trigger, condition, property or anything that was named FUPAN and in fact it was used in the conditions expressions. That was weird. Then I created the property and all started working fine with FUPAN.
Thank you, and please let me know if you need anything else. I am not attaching log because debugging was turned off, but if you need it, I can try to reproduce the issue with debug mode enabled.
