Wiring help
Am heavily leaning towards VEra 3 controller over home seer syetem.
Asked a question elsewhere and z-waver was nice enough to suggest that hard wiring my new home project would have better performance then a simple zwave system,
Need a little guidance.
Drywall is not up yet (about 1-2 weeks away).
Windows and doors are in.
What kind of hard wiring and type of wiring should I ask electrician to do to make this system compatible with a vera 3 for door open/close alerts/alarm/occupance sensors/door lock controls etc…
HOw do I interface these wires with vera 3?
The general recommendation seems to be to use standard alarm system wiring for door sensors and, in particular, PIRs. Anything to avoid a battery device. Then interface Vera with a proper alarm panel such as DSC (see a multitude of others posts on this).
Z-Wave generally fine for lighting, with modules placed in wall boxes - make sure you get extra deep boxes to simplify module installation. Also, I’d just run Cat-6 everywhere.
thanks…PIRs? What does that stand for?
A passive infrared sensor (PIR sensor) is an electronic sensor that measures infrared (IR) light radiating from objects in its field of view. They are most often used in PIR-based motion detectors.
Its hard to run too much LAN cable, too.
Have cat 6 going to wherever there might be a phone jack in the house (bedrooms/offices /kitchen etc) At least I had the foresight to do that.
Have also prewired for cameras all around the perimeter.
SPoke with builder…we are having someone come out friday to discuss prewiring for alarms and window openings…
I will ask him about a few PIR sensors…
Thanks for help!
Oh - and make sure the alarm panel is one that can be interfaced to Vera !
Honeywell Vista 20p or 15p etc…
[quote=“gadget12345, post:7, topic:174770”]Oh - and make sure the alarm panel is one that can be interfaced to Vera !
Honeywell Vista 20p or 15p etc…[/quote]
As akbooer mentioned…
…and commence flame lighting :slight_smile:
Another consideration is the standard lighting wiring. To use Z-wave switches for your standard lighting you must have a neutral wire in the switch box. Don’t let your electrician use “loop” wiring, where they use a standard 2 conductor wire to pass the hot to/from the switch. The white wire, instead of running a neutral, is used to pass the hot back to the light fixture. The neutral never runs from the fixture to the switch. Make sure they use 3 conductor; 2 conductors to pass the hot to/from the switch, and the 3rd conductor to bring a neutral along. You’ll be glad you did when you try to wire up the switches for Z-wave!
