Vera3 with UI5, Leviton VRS15-1LZ switches (and many other devices)
Problem is that a short time (1 or 2 days) after installing Wink Connect V0.22b1, the Vera3 does not act on notifications from Leviton VRS15-1LZ switches on the Vera3 controller. Also, in prior tests, I observed that the Vera3 was not receiving (or processing) notifications from Wink Hub devices.
This problem has been dogging me for months with this and prior versions of Wink Connect. I can not say for certainty that the Wink Connect is causing the problem, but I have done extensive tests that point to the Wink Connect.
The Wink Hub has only light devices attached, and about 5 light devices (specifically the VRS15-1LZ switches) are on the Vera3. All the sensors and security devices are on the Vera3. The Wink Hub has no automation; it is used solely to network lighting devices. All automation is in the Vera3. The most recent test as follows:
4/28/16 At start of procedure, the VRS15-1LZ device notifications were not working. Uninstalled Wink Connect and VeraAlerts so only plugin was the Countdown Timer. Removed all Scenes related to Wink connected lights. Ran backup of Z-Wave network and Vera3. Reinstalled UI5-1.5.622 WITHOUT doing a factory reset on Vera3. Rebooted unit by power cycling. The VRS15-1LZ device notifications were still not working at this point. (Incidentally, I added associations to each of the VRS15-1LZ switches to “help” the notifications: ConfiguredAssoc 1,1.1)
4/29/16 Performed a factory reset on the Vera3 by using the reset button. Reset the Z-Wave Network. Reloaded UI5-1.5.622 with Factory Reset selected. Reinstalled VeraAlerts. Manually removed all of the Wink Connect files that remained after the uninstall. Restored the Z-Wave network and configuration from the backup file. The The VRS15-1LZ device notifications worked properly after this step.
5/14 Tested VRS15-1LZ device notifications. They still worked fine. Manually installed Wink Connect. Did NOT install any scenes that controlled Wink devices.
5/16 Tested VRS15-1LZ device notifications as well as device notifications from Wink connected devices. All notifications still worked fine. Manually restored all scenes that had been deleted. Rebooted Vera3. (Memory 14% cached, 0% buffered, 63% free). Device notifications from all VRS15-1LZ devices stopped working. Wink connected device notifications still working with delays under 20 seconds.
I do not have a long history with Vera, nor do I have any expertise with Linux. I do have some tools and welcome any suggestions.
Incidentally, I have two Vera3 units. At one point, I took my backup unit and retored it from a backup of my active unit. The backup unit demonstrated the same problem.
