Window Door Sensor Generic
I’ve purchased a set of window/door sensors from Aliexpress.com The information from the supplier is woefully in adequate and they don’t seem to respond well to requests for the config file. IS there any way to view the information it is sending to the controller after it is connected to troubleshoot it. I can connect the device but nothing more. It shows an on/off switch on the controller when I connect it and then fails to connect when i click the on button.
