Is there any way to make a shortcut widget for a scene that will be on the home screen.
Yes this is super easy, just get VeraMate in the edit mode but tapping the four stripe icon in the upper left of the home screen. The icons will start to wiggle, in the section that you want to add a scene button to press the “add button” button and then scroll to your scene and select it. You will now have a button on your home page that will execute your scene when pressed.
