why is it necessary to put scenes in separate rooms? I found that if I put scenes in a room called Scenes, I can use the mobile application on my home computer to activate Scenes by voice with dragon naturally speaking. Is there some reason that I shouldn’t do this.
Great idea, lescombs! I think rooms are just a way of organizing things so you can find them in the UI, so this should work well. I’m gonna try it.
I use global scenes for this. They appear at the top of the dashboard.
-GT
