As an example, I have several Kwickset locks that show a nice little icon of a lock when I click on the lock/unlock button but after some period of time they resort back to a circle. This happens with all my lights, locks, sensors etc.
Thanks for the response, I appreciate you sending the info. As an employee of Microsoft, I’m a pretty committed user of Internet Explorer I’m going to run this to ground and find a solution since moving to chrome isn’t really an option for me.
Sorry to hear it’s our technology causing this issue but hopefully I can help find a permanents solution.
I was pretty dedicated to IE until version 10. 10 and 11 are horrible, I’ve had tons of issues with websites and the Java runtime not launching properly and just general performance issues. After that I moved to chrome and couldn’t be happier (even if they do collect my browser history).
There is a rather complicated fix for your issue, I linked to it above, where you change the java script in the Vera files. But, I wouldn’t bother with it, frankly.
I’m sure you know that you can use another browser. Also, hopefully, the issue is resolved in UI6 and beyond.
Hi z-waver
Yes I know about it, thanks.
I know nothing about ssh, but I have seen that it might be possible to go throug info viewer (which cannot be downloaded in IE, a more sevire IE problem).
And if it was a large problem I would use an other browser. It does not affect functionallyty, but it would be nice if it was fixed.
Gengen, I think he made the fix, has done a good job in finding a solution.
Regards
CE
We’re not forced to use IE per se but we do “eat our own dogfood” With all of us using our products we can find these type of edge cases that aren’t caught in testing.
Thanks again for the info.
-Jasone
