curious why a few threads lately do not wrap properly and one has to scroll right to read them?
I thought it was just me seeing that…
It started right after MCV posted in the .1183 regressions thread.
But i’m not pointing the finger of blame!! ;D
JOD.
If someone posts a “code” block (using the [#] button above), and the code block contains wide lines (no CR/LF chars) then this can happen.
The most common case I’ve seen is where someone uses the “code” tag around Log file output.
To give you an example:
http://forum.micasaverde.com/index.php?topic=5466.msg31671#msg31671
It’s not particularly wide, but it is forcing the browser width due to the long conditions at the bottom… not that wide, but just to give an example.
It’s not a problem of the board, it’s your monitor being too small. ![]()
Hummmm big monitor small …well never mind ;D
